6500 ios upgrade memory requirement
suhailpuri
hi all ,
I am upgrading 6500 switch from old ios to new one and the new one requires 512/512 memory to be free below is the show ver and sh sup-bootflash , please tell me how is it calculated as well
thanks
Suhail
sw-cta2-i8-off>sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9-VM), Version 12.2        (33)SXH3a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 24-Sep-08 15:32 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
sw-cta2-i8-off uptime is 2 weeks, 1 day, 9 hours, 9 minutes
Uptime for this control processor is 2 weeks, 1 day, 9 hours, 8 minutes
Time since sw-cta2-i8-off switched to active is 2 weeks, 1 day, 9 hours, 8 minut        es
System returned to ROM by reload at 07:13:53 CET Wed Feb 6 2013 (SP by reload)
System restarted at 07:17:03 CET Wed Feb 6 2013
System image file is "sup-bootdisk:s72033-ipservicesk9-vz.122-33.SXH3a.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6506-E (R7000) processor (revision 1.1) with 1040384K/8192K bytes of memory.
Processor board ID SAL1246A5SW
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
41 Virtual Ethernet interfaces
194 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Patching is not available since the system is not running from an installed image. To install please use the "install file" command
sw-cta2-i8-off>sh sup-bootf
-#- --length-- -----date/time------ path
1     92543652 Nov 10 2008 08:56:32 s72033-ipservicesk9-vz.122-33.SXH3a.bin
2     33554432 Nov 10 2008 14:19:08 sea_log.dat
3       319374 Jul 26 2010 00:48:16 crashinfo_ios-base-20100726-004810
4    133050684 Feb 21 2013 09:22:06 s72033-ipservicesk9-vz.122-33.SXI10.bin
5       309170 May 03 2011 10:13:48 crashinfo_ios-base-20110503-101343
6       333325 Jun 05 2012 12:45:38 crashinfo_ios-base-20120605-124532
7       323301 Nov 05 2012 18:51:48 crashinfo_ios-base-20121105-185143
251658240 bytes available (260448256 bytes used)
InayathUlla Sharieff
Hi Suhail,
Please have a look into the link below:
Out of 512 MB of memory 260 MB has been utilized by 2 IOS and 4 Crashinfo file and few by Sea_log.
2) What is the IOS which you want to upgrade on to? The 512 means that the firmware atleast require this much memory to be available on the Sup to run the firmware it doesnt mean that 512 should be free.
3) I belive you are trying to s72033-ipservicesk9-vz.122-33.SXI10.bin? If yes then you can go ahead and boot this firwmare which will run fine and after it sucessfully booted you can remove the old fimrware which is available on the disk/flash.
Please find below link which gives more on the memory related on different sup:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/qa_c67_457347.html
Kindly revert back for any clarification.
Inayath
*Plz rate the usefull posts.
