High number of Collisions
yujilaw02962
Hi,during 1 of the troubleshooting i found that there are high number of collisions in my WAN interface.And it caused the IP phone can't get registered in my HQ's CCM.But the phone will back on after 1 day or few hrs later.Is it due to duplex mismatch?
Would much appreciate if you can help me point out the problem.
interface GigabitEthernet0/1
description External LAN/WAN
ip address 210.193.5.66 255.255.255.240
ip access-group 130 in
ip inspect myfw out
ip nat outside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
crypto map rtpex
service-policy output policyvoip
GigabitEthernet0/1 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 0018.1891.6b39 (bia 0018.1891.6b39)
Description: External LAN/WAN
Internet address is 210.193.5.66/28
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 255/255, txload 1/255, rxload 5/255
Keepalive set (10 sec)
Half-duplex, 10Mb/s, media type is T
output flow-control is XON, input flow-control is XON
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 19:03:56
Queueing strategy: Class-based queueing
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/49/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 6988 kilobits/sec
5 minute input rate 205000 bits/sec, 6 packets/sec
5 minute output rate 5000 bits/sec, 7 packets/sec
266884 packets input, 168546649 bytes, 0 no buffer
Received 3171 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast, 0 pause input
371844 packets output, 39383741 bytes, 0 underruns
0 output errors, 214 collisions, 0 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
5 Replies 5
Calin C.
Level 5
Level 5
Hi there!
Your line is set to Half-duplex, 10Mb/s on a Gigabit interface. Auto-negotiation of speed and duplex failed. Try to set manual the duplex and speed on the interface (should be the same on both sides) and then clear the counters and see if the collisions increase again.
Good luck!
Cheers,
Calin
Thanks for the reply.
The other end is connected to a modem which provided by the isp,so i don't know their speed.Probably is not auto because i tried set my WAN int to auto duplex,the collision went up fast and furious.
Is there anything i can do to know the setting of that modem?
Hello!
What kind of connection you have there? As I see your config there is a regular line and it should be no modem there (maybe a switch or something) You can actually see the modem?
If you don't know for sure what is the opposite peer, try "show cdp neighbors detail" and if you are lucky enough to have a Cisco device as peer you can see the duplex and the speed you assume after the interface description.
Otherwise...I don't know.Ask your provider. They should give you all the necessary details related to their connection.
Cheers,
Calin
Giuseppe Larosa
Hello Yuij,
a level of collisions less then 0.1% is considered normal in 10 Mbps half-duplex
Use the show interfaces ethernet command to check the rate
of collisions. The total number of collisions with respect to the
total number of output packets should be around 0.1 percent or
less.
in your case:
214 /371844 < 0.1%
This is normal behaviuor for half duplex.
Collided frames are retrasmitted
How 214 collisions in 19 hours can block a phone registration is difficult to understand.
I would investigate other aspects of the problem : ACLs, the configuration of the dhcp pool (have you got the correct option 150 pointing to tftp servers in the CM cluster).
Hope to help
Giuseppe
Hi,we are now looking at all possible aspects in config,hardware and asp.
The problem sometimes happen but will recovered by itself after 1 day or so!!
My 2851 have 2 interfaces,1 is to the modem provided by ISP which i physically can see it.Another connected to the cisco 2970.
