Bookmark
Subscribe
587
High overrun on hssi interface.
abhay0212
Observing high overrun on hssi interface. Need to know if any one have idea why.
5 Replies 5
paolo bevilacqua
What router is thay, what is the output interface, what features are enabled is cef enabled ?
Also post the complete show interface.
Router is 3640. Its a bridge interface so lets skip cef. Here is the show interface output.
Hssi2/0 is up, line protocol is up
Hardware is M1T-HSSI-B
MTU 4470 bytes, BW 45000 Kbit, DLY 200 usec,
reliability 255/255, txload 1/255, rxload 6/255
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 05:13:27
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 1208000 bits/sec, 194 packets/sec
30 second output rate 177000 bits/sec, 160 packets/sec
2414032 packets input, 2115674222 bytes, 0 no buffer
Received 218401 broadcasts, 0 runts, 0 giants, 0 throttles
0 parity
8867 input errors, 0 CRC, 0 frame, 8866 overrun, 0 ignored, 1 abort
Hi, on a slow platform like 3640 you have like 0.3% total overruns, it should not be a problem.
Also converting to regular routing should help.
Any cisco docs on this, which says that the overrun on 3640 with hssi interface is common.
This would help me very much.
Not really, on the other hand is understood that the 3640 is not adequate to deal with the traffic bursts typically associated with hssi and bridging.
