host has no internet and can’t ping external IP's on C897VA
G3000LEE
I'm having an issue getting inside hosts internet access which is connected to the router.
I have configured this model of router a few times in the past using vdsl with success in my own home, but I can't get it working using the WAN ethernet port for a friend.
There is an extra static route in the routing table 141.XX.144.27 which must have been put there by the ISP, but not sure why it's there.
Please see the below output and thanks in advance for any help.
C897VA#show run
no ip source-route
ip dhcp pool HYPEROPTIC100
network 192.168.100.0 255.255.255.0
default-router 192.168.100.254
dns-server 8.8.8.8 8.8.4.4
ip cef
interface GigabitEthernet0
switchport access vlan 100
no ip address
spanning-tree portfast
interface GigabitEthernet8
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan100
ip address 192.168.100.254 255.255.255.0
ip nat inside
ip nat inside source list HYPEROPTIC100 interface GigabitEthernet8 overload
ip access-list standard HYPEROPTIC100
permit 192.168.100.0 0.0.0.255 log
deny any log
C897VA#show ip route
Gateway of last resort is 100.64.XX.193 to network 0.0.0.0
S* 0.0.0.0/0 [254/0] via 100.64.XX.193
100.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 100.64.XX.192/26 is directly connected, GigabitEthernet8
L 100.64.XX.210/32 is directly connected, GigabitEthernet8
141.XX.0.0/32 is subnetted, 1 subnets
S 141.XX.144.27 [254/0] via 100.64.XX.193, GigabitEthernet8
192.168.100.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.100.0/24 is directly connected, Vlan100
L 192.168.100.254/32 is directly connected, Vlan100
897VA#ping 8.8.8.8 source vlan 100
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet sent with a source address of 192.168.100.254
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
C897VA#show ip nat translation
Pro Inside global Inside local Outside local Outside global
icmp 100.64.XX.210:3 192.168.100.254:3 8.8.8.8:3 8.8.8.8:3
icmp 100.64.XX.210:4 192.168.100.254:4 8.8.8.8:4 8.8.8.8:4
C897VA#sh ip cef
Prefix Next Hop Interface
0.0.0.0/0 100.64.XX.193 GigabitEthernet8
0.0.0.0/8 drop
0.0.0.0/32 receive
100.64.XX.192/26 attached GigabitEthernet8
100.64.XX.192/32 receive GigabitEthernet8
100.64.XX.193/32 attached GigabitEthernet8
100.64.XX.210/32 receive GigabitEthernet8
100.64.XX.255/32 receive GigabitEthernet8
127.0.0.0/8 drop
141.XX.144.27/32 100.64.XX.193 GigabitEthernet8
192.168.100.0/24 attached Vlan100
192.168.100.0/32 receive Vlan100
192.168.100.1/32 attached Vlan100
192.168.100.254/32 receive Vlan100
192.168.100.255/32 receive Vlan100
224.0.0.0/4 drop
224.0.0.0/24 receive
240.0.0.0/4 drop
255.255.255.255/32 receive
the 'log' keyword at the end of the access list causes your NAT traffic to be process switched, which effectively disables your NAT.
deny any log
Remove the access list altogether and configure this:
access-list 1 permit 192.168.100.0 0.0.0.255
ip nat inside source list 1 interface GigabitEthernet8 overload
Also, make sure your default route is in there:
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 dhcp
deny any log
also, since you are using Vlan 100, you have to manually create it first:
897VA#conf t
897VA(config)#vlan 100
So the entire configuration would look like this (important parts marked in bold
no ip source-route
vlan 100
ip dhcp excluded-address 192.168.100.254
ip cef
no ip address
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan100
ip nat inside
Hi Georg,
Thanks a lot for your help.
Just removing the log from the access-list fixed the issue.  I always create a standard ACL just so I can have a meaningful name but didn't know adding log to the ACL would disable NAT. I have learnt something new.
I'v been using 800 model router in my house and a friends house for years and it's only by luck I didn't add log in my NAT ACL or I would have had this problem years ago.
Vlan100 was already created but doesn't show in the running-config;
C897VA#sho vlan-switch
VLAN Name Status Ports
1 default active
11 noname active Gi7
100 VLAN0100 active Gi0, Gi1, Gi2, Gi3, Gi4, Gi5
Once again Thanks, and you're a star as I was about to drag the router to my house to test it there.
Glad that everything is working.
The 'log' keyword is tricky indeed. Below the 'official' Q&A from Cisco:
Q. Does Cisco IOS NAT support ACLs with a "log" keyword?
A. When you configure Cisco IOS NAT for dynamic NAT translation, an ACL is used to identify packets that can be translated. The current NAT architecture does not support ACLs with a "log" keyword.
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/26704-nat-faq-00.html
