mlacp
Serge D
I am trying to configure mlacp on 2 routers asr903 but the command
port-channel mc-lag
on global configuration mode is unrecognized. When I ignore it and apply the
mclag configuration
the command
show redundancy interchassis
shows the peer as connected from each router. But when I check the port-channel via the command
show lacp multichassis port-channel
I see the lag state is down onthe peer. Is it possible that this issue be related to the command
port-channel mc-lag
I ignored? How can I solve it?
Hi Georg,
I tried it but it didn't work. The port-channel was still down on both routers. And then I added the service instance in bold under the port-channel configuration and it goes up. I think that's what I was missing.
redundancy
mode sso
interchassis group 1
member ip 10.10.10.39
monitor peer bfd
mlacp node-id 1
mlacp system-mac 1111.1111.1111
mlacp system-priority 90
backbone interface Gi0/1/2
interface Port-channel1
lacp fast-switchover
lacp max-bundle 3
mlacp lag-priority 32767
mlacp interchassis group 1
service instance 1 ethernet
  encapsulation untagged
  l2protocol peer lacp
interface TenGigabitEthernet0/0/0
no ip address
lacp rate fast
channel-group 1 mode active
redundancy
mode sso
member ip 10.10.10.119
monitor peer bfd
mlacp node-id 2
mlacp system-mac 2222.2222.2222
mlacp system-priority 100
lacp max-bundle 3
mlacp lag-priority 32768
no ip address
lacp rate fast
Thanks, everyone for your support.
Regards.
9 Replies 9
Georg Pauwen
hard to say what you are missing. Do you have
port-channel min-link
configured on each router ? Post the full configs of both routers, and have a look at the document linked below:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/lanswitch/configuration/xe-3s/asr903/lanswitch-ethernet-channel-xe-3s-asr903-book/lanswitch-ethernet-channel-xe-3s-asr903-book_chapter_010.pdf
Hi Georg,
Please find below the full configuration of both routers. In front of the 2 routers, I have equipment from Nokia on which a normal
lacp lag
is configured with passive mode.
========================================PE-2============================================
redundancy
mode sso
mlacp node-id 1
lacp max-bundle 3
no ip address
lacp rate fast
==============================================PE-1=====================================
redundancy
mode sso
mlacp node-id 2
lacp max-bundle 3
no ip address
lacp rate fast
Regards.
I have a feeling that this is the problem (the Nokias). I could not find any information on the mutlichassis functionality working in a multi-vendor environment...
balaji.bandi
what is the version of code on ASR and License you have.
what is other side device model of Nokia ?
BB
Cisco IOS XE
Software, Version 03.18.03.SP.156-2. SP3-ext
License Level: metroservices
The other side device is a level 2 device, a DSLAM.
I am not sure I understand the physical topology, can you post a diagram ? How is the (Nokia) DSLAM involved here ?
The physical topology
try and add the line in bold to both routers:
redundancy
mode sso
--> monitor peer bfd
mlacp node-id 1
lacp max-bundle 3
no ip address
lacp rate fast
redundancy
mode sso
mlacp node-id 2
lacp max-bundle 3
no ip address
lacp rate fast
Hi Georg,
redundancy
mode sso
monitor peer bfd
mlacp node-id 1
lacp max-bundle 3
no ip address
lacp rate fast
redundancy
mode sso
monitor peer bfd
mlacp node-id 2
lacp max-bundle 3
no ip address
lacp rate fast
Regards.
