Host on the switch pings but not the switch itself.
wilfred malana
I just moved a stack of 1900s last night from one 6509 to another as part of a core redesign.
So there were 3 stacks that were moved. One is flaky, host on the switches ping but switch IP addresses won't. Each stacks are redundantly connected to two 6509s using GLBP. I do not see an obvious difference on configuration with the flaky stack and the working stacks.
I broke the redundancy on the switch stack and the switches started pinging except for the first switch on the stack.
Does anyone have any idea?
mohamed.khadr
Is this switch in the same VLAN? Check the switch config.
no vlans. ports are routed
