Hosts in VRF to IGP –w- NAT
walliaralot
I have a couple hosts/nodes in a VRF network that connect to an edge-PE MPLS router that need to be routed into company's IGP/OSPF infrastructure so as to be managed by company's access-control server.
[vrf-host]----[layer2-VLAN-VRF-port]----[PE router -w- SVI-VRF-Gateway]----[Core-IGP-OSPF]-------[ACS]
I would like to "leak" these two hosts, that are in a VRF managed by connecting edge PE router to be routing into company's IGP/OSPF transport via some sort of VRF-to-IGP host-static NAT'ing process if possible.
thank, Kevin
Reza Sharifi
Since the ACS is in global routing table and the host is in a vrf, you need to leak the vrf to global.
Have a look at this link:
http://www.cisco.com/en/US/tech/tk436/tk832/technologies_configuration_example09186a0080231a3e.shtml
Reza Sharifi
that's it.. straight foward.
thank you, Kevin
