How add or remove "?" as a word in a router command
ullasupendran
Hi I have a client router configured with apeer group statement which includes "?" in it.
neighbor Sprint? peer-group
neighbor Sprint? remote-as 0000
neighbor Sprint? description LEVEL
can some one tell me how to get the ? as the charater in the statement .
Ullas
Jerry Ye
Use this key sequence Ctrl+v ? to put the ? as a string.
HTH,
jerry
Jerry Ye
HTH,
jerry
Thanks Jerry .It worked.
Rated as it deserves.
Ullas
You are welcome.
jerry
Mohamed Sobair
Level 7
Level 7
Use the (CTRL + V) to add the ? chracter.
Use the no form of the full command to remove it.
Mohamed
