how can i know maximum Throughput for 1841
wdeebwdeeb
dears All
iam working as network administrator for one company and rightnow we have project to replace static routes over WAN links with BGP.
is there any recommendation from cisco to replace 1841 with any routers series , and how can i know maximum Throughput for 1841 to determine if my router can support the BGP routes.
thanks
vmiller
Level 7
Level 7
How many static routes do you currently support ?
What are your intentions as far as BGP goes ?
     a. how many peers will you need ?
     b. how many routes do you think you will need to accept ?
Throughput is not a function of what routing protocol you run.Its more a fuction of processor,memory, system cpu, and overall interface lodad.
The 1841 is suitabale for small branch office connectivity. I'd be suprised if there is an IOS for this platform that supports BGP.
as per the data sheet...
The modular architecture on the Cisco 1841 router  supports HWIC slots. The newly designed high-speed WAN interface slots  significantly increase the data-throughput capability (up to 800-Mbps  aggregate). Table 6 lists the High Speed WAN Interface cards supported  on the Cisco 1841.
http://www.cisco.com/en/US/partner/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016a59b.html
Hope this helps.
Shelley.
