Routing problem with WLC
wchengcisco
Hello all,
I have the following network set up:
Cisco 2800 RTR --> SW --> non-Cisco WLC
Each trunk link has VLANs 900 (mgmt) and 800 (wireless AP mgmt) included.
Cisco 2800 fa0/0 = ISP, fa0/1.900 = 10.0.0.1, fa0/1.800 = 10.71.0.1
The WLC has 10.0.0.2 set up for VLAN 900 and 10.71.0.2 for VLAN 800.
In the WLC, I also have a DHCP server set up to dynamically assign IPs to the APs so they are auto-discovered:
ip dhcp pool AP800
default-router 10.71.0.2
network 10.71.0.0/24
address range 10.71.0.10 10.71.0.30
And the following static routes are set up in the router and WLC:
router:  ip route 0.0.0.0 0.0.0.0 [ISP IP]
WLC:  ip route 0.0.0.0 0.0.0.0 10.0.0.1
My goal is to get VLAN 900 to talk to 800.  In other words, from the router's fa0/1.900 interface, I need to be able to ping 10.71.0.2 and beyond, but I'm having no luck with that.  I believe I need to add a static route so the WLC knows to forward VLAN 800 packets to 10.71.0.1, but that didn't work out too well.
This is what I've tested so far:
-Cisco 2800:  Able to ping all IPs in the 10.71.0.0 subnet from the fa0/1.800 interface
-Cisco 2800:  Unable to ping any IPs from 10.71.0.2 and beyond from the fa0/0 or fa0/1.900 interfaces
-WLC:  Able to ping all interfaces of the router, but I believe those packet and being routed to the fa0/1.900 interface first.
Any idea would be helpful.  Thanks!
0 Replies 0
