How can I make NAT on a Stick (Cisco 881)
eddyevi71
I try to make Nat on a stick, but not successful. Can somebody give me a hand?
Network Diagram
Config File
interface Loopback0
ip address 10.0.1.1 255.255.255.252
ip nat outside
ip virtual-reassembly
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 60.160.60.138 255.255.255.248 secondary
ip address 192.168.178.1 255.255.255.0
ip nat inside
ip policy route-map Nat-loop
duplex auto
speed auto
ip nat pool external 60.160.60.139 60.160.60.139 netmask 255.255.255.248
ip nat inside source list 10 pool external overload
ip route 0.0.0.0 0.0.0.0 60.160.60.137
ip route 192.168.178.0 255.255.255.0 FastEthernet4
access-list 10 permit 192.168.178.0 0.0.0.255
access-list 102 permit ip 192.168.178.0 0.0.0.255 any
access-list 102 permit ip any 60.160.60.0 0.0.0.7
no cdp run
route-map Nat-loop permit 10
match ip address 102
set interface Loopback0
Peter Paluch
Try swapping the inside/outside designations on the loopback and the Fa4 interface, i.e. the Loopback0 should be configured with ip nat inside while the Fa4 should be configured with ip nat outside. This is because the return traffic first hits the Fa4 interface, and following the logic of NAT, the first interface must be the outside interface in order for the backward translation to take place.
In addition, remove the second entry from your ACL 102 (the one with the public range). You should not need to take special care about the return traffic with the modification I have suggested.
Best regards,
Peter
Peter Paluch
Best regards,
Peter
Thank you, Peter. I will try it...
