How can I test the Level 3 traffic on a 10Gbps interface
asanlu1977
In a laboratory off-line enviroment. I would use in a side a cisco 7500 for instance and a GSR as a main router.
How can I simulate the L3 traffic in order to monitorize the 10G int??
Thanks in advance for your responses.
Rgds
ilya.varlashkin
Level 3
Level 3
what properties of the traffic do yo uneed to simulate? If you only need to test routing and forwarding functionality, then simply plug PC behind your routers. But if you need to measure performance impact of various configurations, you need hardware traffic generator like Agilent or Ixia.
I haven't heard of a 10GigE interface for 7500, though.
it was a 7600, sorry for that.
any more suggestions??
rgds
If you're thinking about performance (e.g. throughput) tests, then I'm afraid you can't avoid hardware traffic generators.
