How connect 2 sites with different subnet
Srinivas N
Dear Firends,
I have problem of Site to Site connectivity
I have 2 sites (Site 1' public ip. 115.119.120.X, local ips are 192.168.1.0, & Site 2' public ip 115.119.187.X, local ips are 192.168.2.0)
Both sires are having different locations & using routers are Maipu 800.
At present both sites are running with internet (each router are configured for DHCP, NATING & DNS for intenet)
Please guide my with complete config, both local systems has to communicate.....
Can I go head with some routers?.... My preperance is existing routers & If it is nessary to change the routers please gude me with config.
Thanks & Regards,
Srinivas. N.
Thanks & Regards,
Srinivas.
Dennis Mink
whats a Maipu 800 router?
in general if you want to connect to sites and route the local IP addresses over the internet, you will require a site to site VPN.  (or GRE tunnel)
thanks
Please remember to rate useful posts, by clicking on the stars below.
