887 router - two outbound NAT on dynamic IP's
darren.g
Level 5
Level 5
Hi.
I've got an 887M router which will be configured with two linke - one ADSL, one 3G - both of which will have (obviously) a separately suppplied IP address from the different ISP's being used. The 3G is a backup - plain and simple - for use only when the DSL service flakes out (which it does often)
Routing is pretty simple - I'll either do soemthing with a bit of PBR, or a simple weighted static, but the NAT has me scratching my head a little.
Can I have two outbound NAT pools (ip nat outside) for each interface which will be used ONLY for traffic going out the interface concerned?
For example, I have one for the primary link
ip nat inside source list 2 interface Dialer1 overload
Can I do the same for the second dialer interface like this
ip nat inside source list 2 interface Dialer2 overload
and have them automatically switch to using the dialer 2 IP for the outbound NAT if the dialer 1 link fails?
I don't think I've ever come across this before, so I'm not sure if it can even be done.
Thanks for any input.
Dennis Mink
darren:
Just go:
interface Dialer 1
Description Primary link ISP1
ip address 78.x.x.x 255.255.255.0
ip nat outside
interface Dialer 2
Description Secondary link ISP2  (3G)
ip address 79.x.x.x. 255.255.255.0
ip nat outside
interface FastEthernet1/1
Description Inside LAN segment
ip address 172.168.60.1 255.255.255.0
ip nat inside
access-list 100 permit ip 172.168.60.0 0.0.0.255 any
route-map isp1 permit 10
match ip address 100
match interface Dialer 1
route-map isp2 permit 10
match interface Dialer 2
ip nat inside source route-map isp1 interface Dialer 1 overload
ip nat inside source route-map isp2 interface Dialer 2 overload
ip route 0.0.0.0 0.0.0.0 79.y.y.y   -----> Primary Default route pointing towards Next hop ip of ISP1
ip route 0.0.0.0 0.0.0.0 78.y.y.y 10  -----> Backup Default route with higher AD (10) pointing towards Next hop ip of ISP2 (3G)
let me know if it works
Please remember to rate useful posts, by clicking on the stars below.
Dennis Mink
darren:
Just go:
interface Dialer 1
ip nat outside
interface Dialer 2
ip nat outside
ip nat inside
