How Connect Cisco 1900 Router to ISP (Home Network)
IT1Andy
Hello! I am currently using Spectrum as my home internet provider. I am trying to do labs and get my CISCO 1900 Router connected to the network. I am having issues trying to get it working. I did a ipconfig on my home computer and this is the information I got.
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : home
IPv6 Address. . . . . . . . . . . : 2600:6c58:4300:7734::92e
IPv6 Address. . . . . . . . . . . : 2600:6c58:4300:7734:65e2:3f7:5be6:8f98
Temporary IPv6 Address. . . . . . : 2600:6c58:4300:7734:9cf9:8d1f:9787:dccb
Temporary IPv6 Address. . . . . . : 2600:6c58:4300:7734:f97c:2ef7:c3f3:8b10
Link-local IPv6 Address . . . . . : fe80::65e2:3f7:5be6:8f98%10
IPv4 Address. . . . . . . . . . . : 192.168.1.11
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : fe80::4ad2:4fff:fef5:6d5a%10
192.168.1.1
I am not sure what I am supposed to use as my default gateway, or what should I get as the IP range on my Cisco router.
2 Accepted Solutions
luis_cordova
Hi @IT1Andy
Try this:
ip dhcp pool lan
network 192.168.2.0 255.255.255.0
default-router 192.168.2.1
dns-server 8.8.8.8
int g0/0 <~ to Spectrum
ip add dhcp
no shut
ip nat outside
exit
int g0/1 <- to LAN
ip add 192.168.2.1 255.255.255.0
no shut
ip nat inside
exit
ip route 0.0.0.0 0.0.0.0 g0/0
access-list 1 permit 192.168.2.0 0.0.0.255
ip nat inside source list 1 interface g0/0 overload
make sure the lines marked in bold match your configuration exactly:
version 15.4
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
--> ip dhcp excluded-address 192.168.2.1
ip dhcp pool lan\
--> default-router 192.168.2.1
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1941/K9 sn FJC1944E5WQ
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.2.1 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
--> ip nat inside source list 1 interface GigabitEthernet0/0 overload
--> ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
6 Replies 6
Abzal
Level 7
Level 7
H @IT1Andy
Log in to your router and do command:
sh run
Then we can see what's wrong and help you.
Best regards,
Abzal
Building configuration...
Current configuration : 1323 bytes
! Last configuration change at 04:28:33 UTC Mon Apr 27 2020
version 15.4
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool lan\
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
redundancy
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip http server
ip nat source list 1 interface GigabitEthernet0/0 overload
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login
end
Router1#
*Apr 27 04:37:31.399: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Apr 27 04:37:32.399: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Apr 27 04:37:38.391: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Apr 27 04:37:39.391: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
*Apr 27 04:37:46.391: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Apr 27 04:37:47.391: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
Router1#
Router1#show run
version 15.4
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool lan\
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
redundancy
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip http server
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login
end
luis_cordova
Hi @IT1Andy
Try this:
ip dhcp pool lan
dns-server 8.8.8.8
ip add dhcp
no shut
ip nat outside
exit
int g0/1 <- to LAN
no shut
ip nat inside
exit
There has been a recent discussion in this community about the issue of static default routes which specify an outbound interface but not specify a next hop. And the same issue appears in this discussion. I would like to say again that while a static route (default route or other route) pointing to an outbound interface (especially if it is an Ethernet interface) but not specifying a next hop address may work it is also possible that it will not work at all (depending on whether the next hop supports proxy arp or does not support it). And even if it does work it is a sub optimal solution. When the outbound interface is Ethernet it is much better to specify a next hop address. Or in cases such as this post where the outbound interface is assigned dynamically and it might be difficult to know what next hop address to use it works to have the static default route configured like this
ip route 0.0.0.0 0.0.0.0 dhcp
Rick
I updated the router with the information listed, but I am still not getting any connection. I have included the Show run information.
version 15.4
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool lan\
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
redundancy
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip http server
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login
end
Router1#
Router1#
Router1#show run
version 15.4
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool lan\
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
redundancy
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip http server
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login
end
version 15.4
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool lan\
dns-server 8.8.8.8
ip cef
no ipv6 cef
cts logging verbose
redundancy
no ip address
shutdown
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip http server
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login
end
