BGP-notification
Hi, in the following link page 11 Example 1, I tried to do it in GNS. I configured RTA the same as the example. I configured RTB with RIP. Finally. I configured BGP on RTC. I copied all commands shown in RTA to RTC. When I configured "nei 2.2.2.2 remot 100" I faced the following notifications.
RTA-->%BGP_SESSION-5-ADJCHANGE: neighbor 2.2.2.3 IPv4 Unicast topology base removed from session BGP Notification sent
RTC--> %BGP_SESSION-5-ADJCHANGE: neighbor 2.2.2.2 IPv4 Unicast topology base removed from session BGP Notification received
Why?
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/26634-bgp-toc.pdf?dtid=osscdc000283
Giuseppe Larosa
Hello miracle_david@yahoo.com ,
you are using a well known document about BGP case studies but it is rather old.
The message that you see should mean that RTA is multi protocol multi address families ready
The Ipv4 unicast address  family is the default in older IOS versions.
You may be using an IOS version with a new different default that allows for MP BGP.
Hope to help
Giuseppe
Giuseppe Larosa
Hope to help
Giuseppe
