how do I clear route-map statistics?
donaghq_2
Hi - I have looked everywhere for a command that will clear the statistics. I am running the following code
c7200-js-mz.121-9.bin
Anyone know - please help...
Richard Burts
Donagh
The privilege level command clear route-map counters is the command that you are looking for. 12.1(9) is pretty old code and I am not clear whether that version of code supports this command. Try it and if it works then you have what you need. If it does not work then you will not be able to clear the statictics until you upgrade the code.
Rick
Rick
It does not work. I will have to upgrade the code. Thanks for your help.
