How do I configure port forwarding?
tdennehy
Level 2
Level 2
I am trying to do the simplest of configurations (I think, anyway) and I can't get it to work.  A little router with a cellular interface (working) and overloading the inside hosts on VLAN1 to hit the internet.  That is working.
I want place a host on vlan1 with IP 192.168.1.102 that has a built in webserver and hit it from the outside.  Not sure what I am doing incorrectly, but it isn't working.  Also want to RDP into a host at 192.168.1.100 - and can't do that either.
I'm stumped.  Any idea what I'm missing?
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname sprint-3g
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
no aaa new-model
clock timezone PCTime -8 0
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.200
ip dhcp pool Inside-IP-Pool
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.4.4 8.8.8.8
lease 45
no ip bootp server
ip domain name yourdomain.com
no ipv6 cef
chat-script cdma "" "ATDT#777" TIMEOUT 60 "CONNECT"
license udi pid C819G-S-K9 sn FTX155865LZ
username cisco privilege 15 secret cisco
controller Cellular 0
ip tcp synwait-time 10
interface Cellular0
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer in-band
dialer string cdma
dialer-group 1
interface FastEthernet0
no ip address
spanning-tree portfast
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
duplex auto
speed auto
interface Serial0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
clock rate 2000000
interface Vlan1
description VLAN1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list PrivateIP interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
ip access-list extended PrivateIP
permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended WebPorts
permit tcp any host 192.168.1.102 eq www
permit tcp any host 192.168.1.102 eq 443
permit tcp any host 192.168.1.100 eq 3389
ip sla 1
icmp-echo 4.2.2.2 source-interface Cellular0
frequency 5
ip sla schedule 1 life forever start-time now
logging trap debugging
access-list 1 permit any
dialer-list 1 protocol ip list 1
no cdp run
control-plane
line con 0
login local
line aux 0
line 3
exec-timeout 0 0
script dialer cdma
modem InOut
no exec
speed 144000
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler allocate 20000 1000
scheduler interval 500
end
5 Replies 5
John Blakley
It looks like you need to add:
ip nat inside source static tcp 192.168.1.102 80 interface cell0 80
ip nat inside source static tcp 192.168.1.100 3389 interface cell0 3389
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Looks like I am still missing something.  Was just reading up on that command as I got your reply, and you seem to be correct, however it still is not working.
The way I see it, I should be able to browse to the external IP address of the cellular router on my smartphone and bring up the webpage.
I know the webpage is working since I can browse to it from a laptop that is on the inside of the network.
Question:...
Do I need to kill these on the router for it to work?
ip http server
Our https decided to start working!  Thanks for the help.
http isn't working, and we are not sure why, but I think we can deal with that since https work.
Thanks again for your help!
Yes, you need to do:
#no ip http server
#no ip http-secure server
