How do I find out how many fans are there in a router with the help of CLI? Specifically cisco3845 with ios c3845-spservicesk9-mz.124-3b.bin
Arun More
       I have an issue where show env o/p is as below, I suspect the FAN 1 which shows failed is not present in router, how do i find out with the help of CLI , how many fans are present in router.
#show environment all
SYS PS1 is present.
       Fan status: Normal
       Input Voltage status: Normal
       DC Output Voltage status: Normal
       Type: AC
       Thermal status: Normal
SYS PS2 is present.
       Fan status: Normal
       Type: AC
AUX(-48V) PS1 is absent.
AUX(-48V) PS2 is absent.
Fan 1 Failed
Fan 2 Normal
Fan 3 Normal
Fan Speed is Normal
Alert settings:
Intake temperature warning: Enabled, Threshold: 55 Core temperature warning: Enabled, Threshold: 70 (CPU: 90)
Board Temperature: Normal
Internal-ambient temperature = 28, Normal CPU temperature = 41, Normal Intake temperature = 22, Normal Backplane temperature = 19, Normal
Voltage 1(3300) is Normal, Current voltage = 3284 mV Voltage 2(5150) is Normal, Current voltage = 5153 mV Voltage 3(2500) is Normal, Current voltage = 2525 mV Voltage 4(1200) is Normal, Current voltage = 1203 mV
Nominal frequency
This means that FAN1 has failed.
Fan 1 Failed
Feb 14 07:31:01.996 GMT: %FAN-3-FAN_FAILED: Fan 1 had a rotation error reported.
Feb 14 07:31:21.996 GMT: %FAN-3-FAN_FAILED: Fan 1 had a rotation error reported.
Feb 14 07:31:41.995 GMT: %FAN-3-FAN_FAILED: Fan 1 had a rotation error reported.
Feb 14 07:32:01.994 GMT: %FAN-3-FAN_FAILED: Fan 1 had a rotation error reported. Feb 14 07:31:01.996 GMT: %FAN-3-FAN_FAILED: Fan 1 had a rotation error reported.
13 Replies 13
cadet alain
Why would it report it as failed if it wasn't present ?
Alain
Hi Alain,
I have seen in some devices when fan is not present it gives o/p as failed? and when i physically checked it was not there.
If at we consider its there inside, how do we can find out its presence, does failed means its presence there?
Arun
ok didn't know about this fact.
I don't see how you can do apart opening the device and verifying.
Alain
To make it more specific in SDM was getting alert as FAN 3 failed, where as FAN 3 was not there in the device and that was switch, and I do not recollect the command o/p where it showed me absent or something like that. So what my q is is there a CLI command which shows the number of FANS present in chasis. Simple rite?
yes simple indeed but aprt from the command you used I'm not aware of any other, maybe some more knowledgeable people will tell you if there is such a command then.
Alain
My second point is does failed confirms the presence of the FAN ?
I would have thought so but you tell that it may not be the case.
Alain
I would have provided you the proof of the it, but unfortunately the snapshot captured machine got crashed and I could not recover the data. But I am very much sure that I have seen it CLI mode where it showed me FAN is not present still i got the error log of failed FAN.
Arun,
Do you show any errors for the fan under 'show logging' ?
Also, "fan failed' should indicate the failure of a fan. But usually you should see errors under 'show logging'
Arun More
yes it does as follows
Again My second point is whether failed means fan is present or absent ?
Fan 1 Failed
Thanks John,
Hi All,
In cisco 3845 router, we are using, in that totally 3 fan, but fan 1 is failed. how to find the serial no of the fan...By using the cli...
thank and Regards
Natarajan
