How do I limit "ip nat inside static route" external access
Brian Taylor
This is probably a dumb question but...
I have the following statement in a Cisco 877:
ip nat inside source static tcp 192.168.0.203 3389 interface Dialer1 3389
I simply want to limit external access to this NAT route to a list of external IP address - that is only certain internet IP address can access this RDP port. How can I do this?
Regards, Brian
5 Replies 5
cadet alain
You can apply an inbound ACL on the Dialer interface like this one:
access-list 100 permit tcp host x.x.x.x host 192.168.0.203 eq 3389
access-list 100 permit tcp host y.yy.y host 192.168.0.203 eq 3389
access-list 100 deny tcp any any eq 3389
access-list 100 permit ip any any
You can also use an ACL permitting the RDP traffic for the desired hosts and match it in a route-map that you refer to in the static PAT statement.
Alain
Thanks Alain,
I tried the following:
access-list 101 permit tcp host 120.28.12.xxx host 192.168.0.203 eq 3389
access-list 101 deny   tcp any any eq 3389
access-list 101 permit ip any any
but when I add the following statement in the Dialer1 interface and try remote desktop from 120.28.12.xxx it fails to connect until I remove this statement again:
ip access-group 101 in
Any ideas?
Regards, Brian
ip access-list extended 101
no 10
10 access-list 101 permit tcp host 120.28.12.xxx  any eq 3389
cadet alain
no comment
Brian Taylor
In the end I rang up Cisco TAC to get this resolved. The answer was:
interface Dialer1
access-list 101 permit tcp host 120.28.12.xxx host 120.29.12.xxx eq 3389
where: 120.28.12.xxx is the external internet address and 120.29.12.xxx is the Dialer1 interface internet address. My mistake was using an internal address (192.168.0.203) as the destination.
Brian
