Static Routing for loadbalancing and failover
i have two MPLS line (intranet line) form different ISPs, in My present network  we are using the static routers, so i want configure it for load balancing and also for fail over.
Kindly guide me regarding this.
Actually i am testing in GNS3 , But it is not happening. Kindly find the configuration file has given as below.
Building configuration...
Current configuration : 1419 bytes
version 12.4
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
archive
 log config
  hidekeys
ip tcp synwait-time 5
track 1 rtr 1 reachability
track 2 rtr 2 reachability
interface Loopback1
 ip address 5.5.5.5 255.255.255.255
interface FastEthernet0/0
 ip address 10.1.2.6 255.255.255.252
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 10.1.1.6 255.255.255.252
 duplex auto
 speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.1.1.5 track 1
ip route 0.0.0.0 0.0.0.0 10.1.2.5 track 2
ip route 1.1.1.0 255.255.255.0 10.1.2.5
ip route 1.1.1.0 255.255.255.0 10.1.1.5
ip route 10.1.1.0 255.255.255.252 10.1.1.5
ip route 10.1.2.0 255.255.255.252 10.1.2.5
no ip http server
no ip http secure-server
ip sla 1
 icmp-echo 1.1.1.1
 timeout 500
 frequency 3
ip sla schedule 1 life forever start-time now
ip sla 2
 icmp-echo 1.1.1.1
 timeout 500
 frequency 3
control-plane
Above configuration belongs to R5 Router. Kindly help me on this regards , i will be grateful to you.
Akash Agrawal
configuration looks ok. What issue you are seeing in your setup? are you not able to see both static routes installed into routing table. you may need to configure "ip sla responder" on node 1.1.1.1. Please provide output of below commands.
- show ip sla statistics
- show ip route 1.1.1.0
- show ip route 10.1.1.0
- show ip route 10.1.2.0
- show ip route 0.0.0.0
-Akash
