How do i verify the configuration backup of switch/router?
Varun Luthra
Dear Flox,
Is there any way to verify the configuration backup? For instance, if i have taken the configuration backup of router in .txt format through tftp server. Then if i need to verify the backup configuration again, so is there any way to cross verify the configuration file of router & switch.
Highly appreciate your support.
Hello
Show archive config differences xxxx yyyyyy will let you compare save config files.
Wherever you are saving the config file via this archive feature it will allow you to compare files, In my example im saving it on the flash:but this can easily be a ftp/ tftp destination.
archive
log config
logging enable
hidekeys
path flash:/$h  <can be ftp/tftp  /$h specifys hostname of device in archives
time-period 10080
end
archive config
<---initiate a archve
show archive config differences flash:Sep-25-18-37-26.043-1 system:running-config
or
show archive config differences tftp xxxxx/:Sep-25-18-37-26.043-1 tftp xxxxx/:Aug-25-18-37-26.043-1
STAN#show archive | sec Archive
Archive # Name
1 flash:STANSep-25-18-36-50.636-0
2 flash:STANSep-25-18-37-26.043-1 <- Most Recent
!Contextual Config Diffs:
!No changes were found
Kind Regards
Paul
