How do you filter the default-orignate from a network?
chris.harwell
I have 2 ASA's connected to 2 ISP's. One with default originate metric 1 and the backup with default-originate metric 5. how do have one specific network use the backup as a primary? Lets say I have 10.0.0.0/8 use primary but I want the specific 10.10.0.0/16 to use the backup.
purohit_810
Level 5
Level 5
On Below link,
You need to follow ROUTER -1 Configurations:
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009487d.shtml
Dharmesh Purohit
Thanks Dharmesh! So would mine look like:
default-information originate metric 1 route-map MAP
route-map MAP permit 10
match ip address 10
access-list 10 deny 10.10.0.0 0.0.255.255
access-list 10 permit 0.0.0.0 or 10.0.0.0 0.0.0.255
purohit_810
Level 5
Level 5
You need to configure only below configuration
hostname R103
interface Ethernet0/0
ip address 10.10.34.3 255.255.255.0
interface Serial8/0
ip address 10.10.13.3 255.255.255.0
router bgp 10
no synchronization
bgp log-neighbor-changes
network 10.10.34.0 mask 255.255.255.0
neighbor 10.10.13.1 remote-as 11
neighbor 10.10.13.1 default-originate
neighbor 10.10.34.4 remote-as 10
neighbor 10.10.34.4 next-hop-self
no auto-summary
Dharmesh Purohit
