How I can configure the traffic between 2 networks in a ASA5520 Firewall?
dnievesr01
Hi everyone!
I have a firewall ASA 5520. In this time I have connected 3 networks (192.168.1.0 INSIDE, 192.168.2.0 INSIDE2, 10.0.1.0 OUTSIDE). I follow the article
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080b7c91b.shtml to configure my firewall, but the ASA no permit  traffic (ip, udp, icmp, etc) between the networks.
The configuration that i have is:
ASA Version 8.2(1)
hostname Firewall
domain-name xxxxxx.com
enable password yO4Ejs1n.tA6HaQV encrypted
passwd yO4Ejs1n.tA6HaQV encrypted
names
interface GigabitEthernet0/0
description Interfaz switch segmento#1
nameif INSIDE
security-level 0
ip address 192.168.1.97 255.255.255.0
interface GigabitEthernet0/1
description Interfaz Router 2901
nameif OUTSIDE
security-level 0
ip address 10.0.1.2 255.255.255.0
interface GigabitEthernet0/2
description Interfaz DMZ hacia SG500
shutdown
nameif DMZ
security-level 100
no ip address
interface GigabitEthernet0/3
description Interfaz switch segmento#2
nameif INSIDE2
security-level 100
ip address 192.168.2.97 255.255.255.0
interface Management0/0
nameif Managment
security-level 100
no ip address
ftp mode passive
clock timezone PST -4 30
dns server-group DefaultDNS
object-group network LISTA_OBJETOS
network-object 0.0.0.0 0.0.0.0
pager lines 24
logging asdm informational
mtu INSIDE 1500
mtu OUTSIDE 1500
mtu DMZ 1500
mtu INSIDE2 1500
mtu Managment 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (INSIDE) 1 0.0.0.0 10.0.1.0 outside
route OUTSIDE 0.0.0.0 0.0.0.0 10.0.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 Managment
http 192.168.1.0 255.255.255.0 INSIDE
no snmp-server location
no snmp-server contact
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
management-access Managment
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 averag
e-rate 200
ntp authenticate
ntp trusted-key 1
ntp server 192.168.1.53
webvpn
username xxxxxxxxx password CdAMETwKsUa5iUqQ encrypted
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
  message-length maximum client auto
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:5545c38ac7ca264e2a38caf72b5acb4e
: end
cadet alain
can you do this:
inspect icmp
same-security-traffic permit inter-interface
no nat (INSIDE) 1 0.0.0.0 10.0.1.0 outside
nat (INSIDE) 1 0 0
nat (INSIDE2) 1 0 0
global(OUTSIDE) 1 interface
global(INSIDE2) 1 interface
security-level 100
you should be able to communicate from inside and inside2 to outside and from inside to inside2.
Alain
cadet alain
can you do this:
inspect icmp
nat (INSIDE) 1 0 0
nat (INSIDE2) 1 0 0
security-level 100
Alain
