PKT CCNA 4 Exploration 8.5.1
                   Ive got the everything working and communitcating. when i go to ping PC3 to PC1, it will ping the 1st attempt, then the next attempt it will not ping? any idea?
if i need to post everything jsut let me know
2 Accepted Solutions
this is not an error but just inbound and outbound LCP( pkt type 0xc021) frames.
Alain
seems like you're doing load-balancing, I'm gonna take a look at your PT file.
So, if you remove the antispoofing2 ACL on f0/1 of R1 the ping is ok, i'm gonna investigate further and keep you informed.
Alain
6 Replies 6
i ran: debug ppp packet
and this is the error:
Serial0/0/1 PPP: I pkt type 0xc021, datagramsize 104
Serial0/0/1 PPP: O pkt type 0xc021, datagramsize 104
Alain
*smacks forehead* ive been  troubleshooting this for 3 days.
from pc 3 this is the display when i ping:
pc1: ip address 192.168.10.10
pc3: ip address 192.168.30.10
PC>ping 192.168.10.10
Pinging 192.168.10.10 with 32 bytes of data:
Reply from 192.168.10.10: bytes=32 time=205ms TTL=126
Reply from 10.3.3.1: Destination host unreachable.
Reply from 192.168.10.10: bytes=32 time=187ms TTL=126
Ping statistics for 192.168.10.10:
    Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
Approximate round trip times in milli-seconds:
    Minimum = 109ms, Maximum = 205ms, Average = 313ms
tracert isnt looking right either?????
cadet alain can you take another look for me please? or anyone?
Alain
that fixed the ping issue. tracert from pc3 still is looking funny??? think that could be the last 7% of the packet tracer?
