How I can create interface vlan on C8300
username11
I find a problem when I want to configure a interface vlan on C8300 . Any solution
20 Replies 20
Hi all
Just I need a clear phrase that c8300 doesn't support interface vlan .
rchinnam
On C8300's you need to have a ES3 card to enable VLAN SVI's. Once you insert the ES3 card you should  reload the router and should be able to configure l3 SVI's.
RAMA
@rchinnam, have you tested 8300 with ES3 module that supports interface-vlan?  Or you mean ES2 module?
fabio.alves111
How did you solve this issue?
grich1
Hello
You have already been provided a solution , you need to dot 802.1q tagging (subinterfaces)
Kind Regards
Paul
