How is the processing order of nat rules with routemaps determined?
john-herdy
Hi network gurus,
(part of the configuration)
interface FastEthernet0/1
ip nat enable
ip nat source route-map RMAP1 pool POOL1 overload
ip nat source route-map RMAP2 interface FastEthernet0/1 overload
access-list 1 permit 10.4.0.0 0.0.255.255
access-list 2 permit 10.0.0.0 0.255.255.255
route-map RMAP1 permit 10
match interface FastEthernet0/1
match ip address 1
route-map RMAP2 permit 10
match ip address 2
ip nat pool POOL1 192.168.1.10 192.168.1.10 netmask 255.255.255.0
When I connect from 10.4.0.1 I get RMAP1. When I connect from  10.3.0.1 I get RMAP 2. This is the desired result, but I want to  understand why?
10.4.0.1 also matches with access-list 2. I have tried to change  the order of all components in the configuration but I always get the  same result. Is this done automatically, because access-list 1 is more  specific/explicit? Without removing RMAP2 is it possible to match 10.4.0.1 with access-list 1/RMAP1? How can I manipulate the order of processing?
It is  really strange to me, because I cannot explicitly configure a desired  order. Please help me understand. I hope you understand my question. I have googled and read articles for hours, but I can't find this information. I really depend on a network guru right now.
John
blau grana
Level 7
Level 7
Hello John,
Here are some explanations, did you read them?
https://learningnetwork.cisco.com/docs/DOC-8009
https://supportforums.cisco.com/thread/226912
https://supportforums.cisco.com/thread/218467
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Thanks for your help.
The links do not address my question, but I have already learned that route-maps are prioritized by most explicit access-list first.
John
I do not see how I can close solved questions.
