how many catalyst 4500Xs can be stacked to gather?
Omid Almasieh
Hi folks ,
I'm designing a hierarchical 3 layer campus network with different switch blocks .We need 10Giga Ethernet in the core to distributions and access layer , I was thinking about using a pair of catalyst 4509E in each block.after that I got interested in 4500Xs , in comparison with 4509Es they are much thinner and saves more room in rack space .I wanna use 4500X in my distribution layer .
The question is , as you know 4500Xs have 40 10Giga Ethernet ports , in some of my switch blocks I have more than 40 access switches (40 uplikns to distribution ) i wanna know how many of 4500Xs can i stack together ?
3 Accepted Solutions
Leo Laohoo
Two units in a VSS.
Bilal Nawaz
Hello, the 4500X is stackable but not in the true sense as the 3750's etc...
With the 4500X's you can enable VSS which is a type of stacking/ HA technology with up to 2 chassis in a stack as stated in the data sheet here:
http://www.cisco.com/en/US/prod/collateral/switches/ps10902/ps12332/data_sheet_c78-696791.html
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
As the other posters have noted, VSS is limited to a single pair.  So your options are to have more than one pair of 4500X distribution pairs when you need more than 40 10g links, or use 6500s as your VSS pair, such as a pair of 6506s.
5 Replies 5
Leo Laohoo
Two units in a VSS.
Bilal Nawaz
Hope this helps
Joseph W. Doherty
Disclaimer
Posting
Thank you guys ...
Thanks for rating our useful posts, Omid.
FYI:  There's going to be a major announcement in regards to the Catalyst switches (possibly on or before Cisco Live San Diego).
