layer 2 traffic from host to router. 887va
dannymcca
i have set up a layer 2 tunnel on my 887va router and the traffic transmits accross this to my second 887va. unfortunately, I do not seem able to get the layer 2 traffic from my host PC and down the tunnel.
I believe the problem to be the router settings for the fastethernet aqnd forwarding this data out of the dialer port.
I am now desperate to resolve this as all of my attempts have failed, I believe this is something very simple I am missing. PLEASE HELP.
Here is my config:
Building configuration...
Current configuration : 3973 bytes
! Last configuration change at 13:03:15 UTC Thu May 2 2013
! NVRAM config last updated at 13:04:17 UTC Thu May 2 2013
version 15.1
no service pad
hostname XXX
boot-start-marker
boot-end-marker
enable secret 4 pozkvcqXiM/f4AVrqz8PjSI9KxXYqhSXdmI.1yi0uD2
no aaa new-model
memory-size iomem 10
ip source-route
ip cef
no ipv6 cef
l2tp-class l2tpclass2
authentication
password xxx
l2tp-class l
vpdn enable
vpdn-group vpdngroup1
accept-dialin
  protocol l2tp
  virtual-template 1
terminate-from hostname xxxxx
license udi pid CISCO887VA-K9 sn FCZ1706908Q
controller VDSL 0
pseudowire-class pwclass2
encapsulation l2tpv3
sequencing both
ip local interface Dialer0
ip pmtu
ip tos reflect
ip ttl 100
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key xxxx address xxx.xxx.xxx.xxx
crypto isakmp keepalive 30 5
crypto ipsec transform-set XXX esp-3des esp-md5-hmac
crypto map Cmap 10 ipsec-isakmp
set peer xxx.xxx.xxx.xxx
set transform-set XXX
match address 101
bridge irb
interface Loopback1
no ip address
interface Ethernet0
no ip address
shutdown
no fair-queue
interface ATM0
no ip address
ip nat outside
ip virtual-reassembly in
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
switchport access vlan 2
no ip address
interface FastEthernet1
switchport access vlan 200
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Virtual-Template1
ip unnumbered Loopback1
ppp authentication chap
ppp chap hostname xxxxx
interface Virtual-PPP2
pseudowire xxx.xxx.xxx.xxx 10 pw-class pwclass2
interface Vlan1
no ip address
ip nat inside
shutdown
interface Vlan2
no ip address
bridge-group 1
bridge-group 1 input-address-list 700
bridge-group 1 output-address-list 700
interface Vlan200
no ip address
interface Dialer0
ip address xxx.xxx.xxx.xxx 255.255.255.0
no ip redirects
no ip unreachables
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap callin
ppp chap password 0 xxxx
ppp ipcp route default
ppp ipcp address accept
no cdp enable
crypto map Cmap
interface Dialer1
no ip address
interface Dialer9
no ip address
shutdown
interface BVI1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 78.105.250.120 255.255.255.255 Dialer0
ip route 192.168.1.0 255.255.255.0 Virtual-PPP2
access-list 50 deny   any log
access-list 100 deny   ip 192.0.0.0 0.255.255.255 192.0.0.0 0.255.255.255
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 192.0.0.0 0.255.255.255 192.0.0.0 0.255.255.255
access-list 101 permit tcp 192.0.0.0 0.255.255.255 192.0.0.0 0.255.255.255
access-list 101 permit udp 192.0.0.0 0.255.255.255 192.0.0.0 0.255.255.255
access-list 101 permit icmp 192.0.0.0 0.255.255.255 192.0.0.0 0.255.255.255
access-list 101 deny   ip any any
access-list 101 deny   tcp any any
access-list 101 deny   udp any any
access-list 101 deny   icmp any any
access-list 111 deny   tcp any any eq telnet
access-list 111 permit ip any any
access-list 700 permit 0000.0000.0000   ffff.ffff.ffff
dialer-list 1 protocol ip permit
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line aux 0
line vty 0 4
access-class 50 in
exec-timeout 0 0
no login
transport input none
transport output none
end
6 Replies 6
paolo bevilacqua
What is the reason why you need layer 2 instead of regular IP ?
I have a Web Ranger which only ouputs the data in layer 2 format.
Thanks..
I don't know if you are referring to the following.
http://www.data-connect.com/RAD_WEB_RANGER.htm
If yes, that is a regular router, if not, please explain.
Hi Danny,
It is hard to say what is wrong with your setup without running debug commands. I have set up a lab with one C887va and one C888E, and successfully running L2TPv3. The relevant part of the config in C887 is as follows. I am using advipservices: c880data-universalk9-mz.152-1.T.bin.
l2tp-class L2_CL
hello 10
password 7 02050D480809  !----->same on both ends
cookie size 8
pseudowire-class L2TPv3_PS
interworking ethernet  !---->you missed this in your config
protocol l2tpv3 L2_CL
ip local interface Ethernet0.10   !---->source layer3 interface
ip dfbit set
interface Vlan1
xconnect A.B.C.D 100 encapsulation l2tpv3 pw-class L2TPv3_PS  !----->destination IP address
The following commands can be used for checking:
show xconne all detail
show l2tp session
show l2tp tunnel
Hope this be helpful to you.
I have made the changes, however, my traffic still will not go down the tunnel.
Is there any debug statements that will show me layer 2/ethernet traffic entering the router and if it is being filtered?
I think the tunnel is working but my traffic is not getting that far.
Please can you advise whether there is a debug statement that shows layer 2 traffic within the router not the tunnel.
Below is the output from she show L2TP command - I am correct in assuming that this is working aren't I?
Danny
The debug L2TP gives the following output:
L2TP Tunnel and Session Information Total tunnels 1 sessions 1
LocTunID   RemTunID   Remote Name   State  Remote Address  Sessn L2TP Class/
                                                           Count VPDN Group
2429948526 1313898432 routername    est   xxx.xxx.xxx.xxx  1     l2tp_default_cl
LocID      RemID      TunID      Username, Intf/      State  Last Chg Uniq ID
                                 Vcid, Circuit
2707157308 3583248854 2429948526 10, Vp2              est    06:41:26 1
Hi Danny,
Can you ping between the source and destination IP's used by the l2tpv3 tunnel?
try using the following debugs:
debug vpdn l2x-events
debug vpdn l2x-packets
"show l2tp session all" shows the counters that also tell you if the traffic is going through the tunnel.
sh l2tp session all
L2TP Session Information Total tunnels 1 sessions 1
Session id 34342 is up, tunnel id 15973
  Remote session id is 2976301299, remote tunnel id 2129208375
  Locally initiated session
Call serial number is 2336700001
Remote tunnel name is XXXXX
  Internet address is 10.93.2.1
Local tunnel name is XXXXX
  Internet address is 10.248.119.26
IP protocol 115
  Session is L2TP signaled
  Session state is established, time since change 7w3d
    151216258 Packets sent, 36833387 received
    775473738 Bytes sent, 3111073773 received
  Last clearing of counters never
  Counters, ignoring last clear:
    Receive packets dropped:
      out-of-order:             0
      total:                    0
    Send packets dropped:
      exceeded session MTU:     0
      total:                    0
  DF bit on, ToS reflect disabled, ToS value 0, TTL value 255
  Sending UDP checksums are disabled
  Receiving UDP checksums are verified
  Session cookie information:
    local cookie, size 8 bytes, value 27 34 0A F5 41 17 93 3B
    remote cookie, size 8 bytes, value C2 FC D6 C0 B3 CD 77 1F
  FS cached header information:
    encap size = 32 bytes
    45000014 00004000 FF73ED06 0AF8771A
    0A5D0201 B166C0F3 C2FCD6C0 B3CD771F
  Sequencing is off
  Conditional debugging is disabled
  SSM switch id is 4097, SSM segment id is 8195
  Unique ID is 5
Session Layer 2 circuit, type is Ethernet, name is FastEthernet0/1
  Session vcid is 100
  Circuit state is UP
    Local circuit state is UP
    Remote circuit state is UP
regards.
