How many endusers can a C2821(256MB RAM) support?
toskie9999
I am working on a C2821 router need to know if it can support 300 plus endusers. The router will be used for forwarding Data to the internet. THANKS!
For such a low speed, you can even use a 2801. Note if you are buying new, a 2901 would be much better.
paolo bevilacqua
Routers don't care about how many users you have.
What matter is the circuit speed. Which circuit spped do you have ?
Also, are you the end user trying to confirm what a cisco partner told you ?
by circuit speed do you mean our connection speed to the internet?? if it is our connection speed we have a dual 4mbps connection
ok thanks a lot you cleared my confusion hehehee. thanks for the advice
