Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yes, such limits are difficult to find. Most are rather "generous" and often you'll first exceed what the router can effectively support before you're limited by its actual logical maximums. Also, some depend on hardware in the device. An example of the latter, RAM for routes.
Of those you ask about, I think CBWFQ supports 255 queues in the later IOS versions.
