08-25-2015 01:14 AM - edited 03-05-2019 02:09 AM
I am using cisco router, i have created sub interfaces, i am using public IPs - Now i need to check the traffic flow...
I need the below details for the same.
1.Source IP
2.Source Port
3.Destination IP
4.Destination Port
5.Date and Time of Access
I Want to capture the above details from the cisco Router.
What is the solution for this, Can cisco help me in this.
Solved! Go to Solution.
08-25-2015 01:30 AM
depending what your hardware/ios is you will need to check what features you have available and what it supports
Most routers are limited that they cannot support SPAN but 3845s can or you could look into using the feature RITE
Some routers also support monuitor capture buffer
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
https://supportforums.cisco.com/document/29616/utilizing-new-packet-capture-feature
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/10570-41.html
http://www.cisco.com/c/en/us/td/docs/ios/12_4t/12_4t11/ht_rawip.html
08-25-2015 01:30 AM
08-27-2015 05:07 AM
Dear Mark,
Thank you very much for your reply.
We have started using the product http://www.unleashnetworks.com/.
We fetch the logs from the Netflow. It analyses well.
It is under observation to check the performance...
