How many users can be connected to a Cisco 1941W at one time?
Gene Erickson
              I see that most Cisco Routers have a recommended user specification but I cannot find one for the 1941W, does anyone know what the recommend (maximum) user rating is for this router?
6 Replies 6
paolo bevilacqua
Number of user does not matter, can be 1 or 1000.
What matters is you internet circuit speed, that you have not mentioned.
Leo Laohoo
You talking about the router or the wireless?
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Alhough small router datasheets often suggest a model for some number of users, they are really sized for the bandwidth that might pass through them.  For example, just two hosts with gig between them might require a ASR1K to support that much bandwidth (NB: normally we would use a small switch, perhaps L3 capable, for a situation like this).  For a fractional T1, you could have thousands of hosts using a router even smaller than a 1941 (hope those thousands of hosts don't do much across that fractional T1).
As to wireless, it to depends much on bandwidth being supported but often the controller might have a logical host limit (sometimes controlled by usage license).  I.e. for the former something like 801.11b wouldn't require a very power network device, 801.11n requires a more powerful network device.
This is where the problem arrises , the connection speeds can vary depending upon the customer, I was looking for a "guideline" of sorts of what the device is capable with the follwoing minimum parameters.. And this would be for the wired users not the wireless.
TCP/IP Network
100Mbit Switched LAN – Workstation LAN Access
Gigabit Switched Backbone LAN (Required)
Permanent High-Speed Internet Connection w/ Static IP
Thank you everyone for your input!
Minimum 512Kbps TCP/IP WAN Branch Connection
Check attached.
As with most things the answer is "it depends".
What kind of traffic are you looking to support (data / voice) and is latency an issue?
Are you planning to use any advanced features (IPSEC / NAT / QoS)?
You mention that you will have a minimum 512Kb WAN link - if this is typical then this will be bottleneck in your design, not the router itself.
