Showing results forĀ
Search instead forĀ
Did you mean:Ā
How many WAN ports does a C1161X really have?
I want to buy a new 1161X router and the datasheet mentions 1 and an SFP port, but the image and a friend's equipment show that there are 2 RJ45 WAN ports and one SFP/RJ45, or "combo", so I can deduce  there really are 3 three wan ports, right?
2 Accepted Solutions
balaji.bandi
2 WAN Ports  - One  you can use RJ45 and 1 port dual function you can use RF45 or SFP.
The C1161X-8PLTEP platform has eight Gigabit Ethernet LAN ports, one Gigabit Ethernet WAN port, one Gigabit Ethernet WAN/SFP port
BB
Hello @wladmirmendozandc ,
from the datasheet kindly provided by BB
Also the picture suggests only two ports however you have the device in front of you ...
Do you have 3 RJ45 and one SFP slot in the WAN section ?
Hope to help
Giuseppe
8 Replies 8
balaji.bandi
BB
But the FAQ say
Q.  What is the naming convention for the ISR 1000 Series Product IDs?
A.  1. Prefix
ā€œCā€ = Standard Product ID (PID) prefix
2. Product number
The second portion of Product ID after the hyphen identifies the number of LAN ports:
ā—      ā€œ1161ā€ = Two GE WAN interfaces
Products - Cisco 1000 Series Integrated Services Routers FAQ - Cisco
and there are literally two WAN ports Gig and then an additional SFP/RJ45 port
you need to read other FAQ also in the document to get more accurate answer
always refer the product document :
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html#Cisco116xISRsHighperformancesmallformfactor
BB
as in other router platform you probably can choice between RJ45 and SFP for one port using the interface command
media-type rj45|sfp
You have two WAN ports one that is RJ45 only and one that is dual mode.
Hope to help
Giuseppe
Hello
It is an honor to receive a response from you
We just tested the C1161X model with 8 GB of RAM with a friend and we did not agree with what the datasheet says....
The C1161X has two WAN ports rj45 only and additionally they have an rj45/sfp (or combo) WAN port. We apply the command you refer to (media-type rj45|sfp) and it works perfectly for us.
In summary, 1161X has 3 WAN (2ports RJ45/ 1ports (combo) ) ports but this information does not match to me what the documentation says... or maybe I did not read it correctly
Hope to help
Giuseppe
I have two ports (RJ45) + one SFP/RJ45 combo port
For me this agrees with what the FAQ says but not with what the Datasheet says
FAQ says
A. 1. Prefix
2. Product number
Hi @Giuseppe Larosa
Hi @balaji.bandi
Very Veery sorry both, I had a lot of confusion, as you have told me there are two WAN ports (0/0/0 and 0/0/1), if I am going to use the SFP port, that port would override the WAN port, specifically 0 /0/0
Thank you very much and sorry for the inconvenience and Thank you both for your patience.
