How much bandwidth is being used?
jamesgonzo
How can I find out how much bandwidth is being used?
I have run a 'sh dsl interface'
877# sh dsl interface
ATM0
Alcatel 20190 chipset information
ATU-R (DS) ATU-C (US)
Modem Status: Showtime (DMTDSL_SHOWTIME)
DSL Mode: ITU G.992.1 (G.DMT) Annex A
ITU STD NUM: 0x01 0x1
Vendor ID: 'STMI' 'GSPN'
Vendor Specific: 0x0000 0x0008
Vendor Country: 0x0F 0xFF
Chip ID: C196 (0)
DFE BOM: DFE3.0 Annex A (1)
Capacity Used: 93% 54%
Noise Margin: 11.0 dB 14.0 dB
Output Power: 18.5 dBm 3.5 dBm
Attenuation: 50.0 dB 31.5 dB
Defect Status: None None
Last Fail Code: None
Watchdog Counter: 0xD1
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction: 0x00
Interrupts: 12397 (0 spurious)
PHY Access Err: 0
Activations: 4
LED Status: ON
LED On Time: 100
LED Off Time: 100
Init FW: init_AMR-3.0.014_no_bist.bin
Operation FW: AMR-3.0.014.bin
FW Source: embedded
FW Version: 3.0.14
Interleave Fast Interleave Fast
Speed (kbps): 3776 0 416 0
Cells: 7426697 0 9783331 0
Reed-Solomon EC: 17552 0 17 0
CRC Errors: 0 0 1 0
Header Errors: 0 0 0 0
Total BER: 0E-0 0E-0
Leakage Average BER: 0E-0 0E-0
Bitswap: enabled enabled
Bitswap success: 0 0
Bitswap failure: 0 0
LOM Monitoring : Disabled
It says 93% and 54% capacity is being used is this the DSL line? and is tht 93% inbound?
Pravin Phadte
Level 5
Level 5
its not the capacity.
Its the Speed
Speed (kbps): 3776(Interleave) 0(Fast) 416 (Interleave) 0 (Fast)
3776 is IN and 416 is out.
