How SG200 can be configured with ACS Radius for Management Access
Sayyidi91
I have SG200 which running version 1.4.7. At the same time, in the environment there is an ACS Radius configured. At the moment this SG200 only configure as an access switch with Port Based Access Control (802.1x) through the radius. In future, I would like to configure this SG200 with Management Access using the same radius. However according to this link
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-200-series-managed-switches/smb102-radius-configuration-on-the-200-300-series-managed-switches.html
it stated should be able to configured with SG200. But only issue thing that I can see that the interface of the configuration is totally different than mine and also at the moment Im not sure either SG200 are capable to configured with Management Access using radius.
If can, kindly help to show me how.
0 Replies 0
