Configuring l2vpn mpls - Layer 2 Tunneling
Lost & Found
Level 2
Level 2
Hi Everyone,
Anyone here had configured transparent l2TP? We have a l2vpn circuit running and we want the link to be fully transparent. According to cisco " If the routers are not configured to tunnel Layer 2 PDUs, the peer PE router on the far end of the network cannot properly run the STP, CDP, and VTP protocols. ", so what I did is to enable tunnel and add the specific l2procol but the result is not successful.
Topology:
SITE A------| SW1--PE1------l2vpn------PE2--SW2 |------Site B
Current configuration:
SW1 - interface GigabitEthernet1
switchport mode trunk
switchport trunk allowed vlan 10
PE - interface GigabitEthernet0/0.10 l2transport
encapsulation dot1q 10
rewrite ingress tag pop 1 symmetric
l2vpn
Xconnect group lab01
p2p lab01
interface Gig0/0.10
neighbor ipv4 2.2.2.2 pw-id 10
PE2 - interface Gig0/0.10 l2transport
l2vpn
p2p lab01
interface Gig0/0.10
neighbor ipv4 1.1.1.1 pw-id 10
SW2 - interface Gig0/0
service instance 10 ethernet
encapsulation untagged
bridge-domain 10
I have added some change on switch to enable transparent L2PT. 1 enabled 802.1Q tunnel on the port add specify the l2protocol.
(C4500)sw1 :interface GigabitEthernet0/0
switchport access vlan 10
switchport mode dot1q-tunnel
l2protocol-tunnel cdp
l2protocol-tunnel lldp
l2protocol-tunnel stp
no cdp enable
(ASR920) sw2 : interface GigabitEthernet0/0
encapsulation default (should i use untagged or default to match packets?)
l2protocol tunnel cdp stp lldp (After adding the l2protocol no traffic can pass the circuit?)
bridge-domain 10
Also does by default I cannot run l2 protocol properly without using some sort of tunneling?
Please help to verify if my configuration is correct and if I'm missing something. Im continuously checking this .
Thank you
what devices are PE1 and PE2, are these both ASR920 routers ?
