how to achieve Multicast RP Redundancy with Static IP ?
hashimwajid1
Level 3
Level 3
Hi All
i need help to configure Multicast PIM Sparse Mode with RP Redundancy for Network Devices without Dynamic Routing Protocol (only static route) . i have following queries
1- can we configure Multicast PIM sparse mode with Dual RP and with Static IP configured on connected device (without any Dynamic Routing Protocol  ( if yes then which method will work   Anycast RP, Auto RP, BSR )
2- if Dual RP cannot be achieve by using Static Routing then what should be the exact method to achieve
3- is there any way we can achieve RP redundancy with static Routing instead of  dynamic routing
4-  why we cannot configure static Routing with dual RP/ RP backup ?
       PIM Sparse Mode
        Multicast Source
                !   L3 SW1                                           L3 SW2
RP1 ---!!!!!!!!-------------------!!!!!!!!!!--- RP2                      HSRP running between SW1 and SW2
                !                                          !                                      HSRP VIP is gateway for SW3 and SW4
     L3 Link    !                                          !   L3 Link
             !!!!!!!-------------------!!!!!!!!!!-----------Multicast Receiver
             L3 SW3                                                         L3 SW4                                                        HSRP running between SW3 and SW4
        HSRP VIP is gateway for Multicast Receiver
we have defined static routing all over the place
waiting the expert opinion
any help will be appreciated
real topology also attached
with sparse mode and exclusively static routing, you might be able to use HSRP Aware PIM. You cannot use MSDP since that requires BGP....
https://www.cisco.com/en/US/docs/ios-xml/ios/ipmulti_pim/configuration/15-2s/imc_hsrp_aware.html
