How to advertise learned iBGP routes to eBGP peer?
Laurent Ost
I'm a student and I'm currently building a full IPv6 lab with a provider backbone in AS 65000 with XR routers and a customer AS 64800 with a CE router and want to redistribute the learned iBGP routes from the backbone to the customer CE peer. I have configured IS-IS for router connectivity in the core over each router's loopback 0. For the XR3 to XE4 I've used a static route.
Afterwards, iBGP was configured to advertise the loopback 1 from XR2 (simulating a network segment) to all iBGP peers which worked. XR1 was used as route reflector to omit the full mesh requirement.
XR3 and XE4 have successfully established eBGP peering but I have currently two problems:
- CE does not receive the BGP routes of XR2 Lo1 through XR3 and XR3 does not receive the Loopback 1 created on XE4.
- I cannot ping loopback 0 (XR3 and XE4) of each other even though BGP peering is successfully established.
Following BGP configuration on XR3:
router static
  address-family ipv6 unicast
    2014::1/128 GigabitEthernet0/0/0/1
    2014::1/128 2001:db8:34::3
router bgp 65000
  bgp router-id 3.3.3.3
    network 2013::1/128
    network 2001:db8:34::/64
    redistribute connected
    redistribute isis 97
  neighbor 2011::1
    remote-as 65000
    update-source Loopback0
      next-hop-self
  neighbor 2014::1
    remote-as 64800
    ebgp-multihop 2
      next-hop-self
On XE4
router bgp 64800
  bgp router-id 4.4.4.4
  bgp log-neighbor-changes
  no bgp default ipv4-unicast
  neighbor 2013::1 remote-as 65000
  neighbor 2013::1 ebgp-multihop 2
  neighbor 2013::1 update-source Loopback0
  address-family ipv4
  exit-address-family
  address-family ipv6
    network 2001:DB8:34::/64
    network 2014::1/128
    network 2114::1/128
    neighbor 2013::1 activate
  exit-address-family
ipv6 route 2013::1/128 2001:DB8:34::3
XR3 has XR2's route.
show route ipv6
B 2112::1/128
[200/0] via 2012::1, 2w6d
Do I have to configure some kind of redistribution for eBGP or is it automatically done and I haven't configured something correctly?
Thanks in advance.
Hi @Laurent Ost ,
With IOS-XR, eBGP drops all inbound and outbound routes by default. You need to configure an inbound and outbound
route-policy
permitting the routes or configure
bgp unsafe-ebgp-policy
to disable the default behaviour.
route-policy pass
pass
end-policy
router bgp 65000
neighbor 2014::1
route-policy pass in
route-policy pass out
or
router bgp 65000
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
6 Replies 6
XR3
router bgp 65000
  neighbor 2014::1
    remote-as 64800
    ebgp-multihop 2 <<-
    update-source Loopback0 <<-
      next-hop-self
between XR3 and XR4 you use loopback as update source but are you config any static or routing protocol for these Loopback??
try use direct connect instead of update-source in all router and check, I think you missing config IGP reach all LO inside AS and between AS.
Thanks for your response.
IS-IS is used as IGP inside the core AS and static routing between the AS. I removed update-source loopback0 and multihop 2 on XR3 and XE4 but it broke the BGP peering. IGP is working fine inside the core, but maybe the static route was not a good idea.
In another lab I configured a similar setup with IPv4, OSPF as IGP and static route between AS (only XE routers) which also worked.
I'll try to configure a L1/L2 IS-IS link between XR3 and XE4. If that doesn't work I'm will configure them all as directly connected instead of going over loopbacks. It's interesting that the peering is established.
Harold Ritter
Hi @Laurent Ost ,
The static routes on XR3 are incorrect. Try the following:
router static
    no 2014::1/128 GigabitEthernet0/0/0/1
    no 2014::1/128 2001:db8:34::3
    2014::1/128 2001:db8:34::4
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi @Harold Ritter,
Thanks, I realized
2001:db8:34::3
was wrong but the removal of
made the ping  finally go through from Loopback0 to Loopback0. Thanks a lot.
However, I still receive no prefixes over the eBGP peer when running:
show bgp ipv6 unicast neighbors 2013::1 routes
Is there some redistribution needed? I would like the advertise the iBGP received route 2112::1/128 of XR2 from XR3 to XE4.
Laurent
Hi @Laurent Ost ,
route-policy
route-policy pass
pass
end-policy
router bgp 65000
neighbor 2014::1
or
router bgp 65000
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi @Harold Ritter,
Awesome, it works! I didn't know about this default behaviour.
Thank you very much.
Laurent
