ISR 2911 replacement
ahmad.syed
Hi team,
We are working on replacing 2911 router which is used for console connection as management router through HWIC card in it. As its EoL , we are replacing it with ISR 4331 which is also EoL .
So , now we are going through ISR 4461 as replacement for 2911 router for same Console connection activities and working as Management router through NIM-16A card.
Can you please confirm on below points:-
  •  is 4461 also EoL announced as i am not seeing any document related to it?
  • IS 4461 supports NIM-16A . I am seeing document but want to reverify
  • Last , is there any other device also recommended which is best for use as Management router ?
 EOL date for 4331 will be 7-11-2023.. as a replacement you can use catalyst 8000 series. C8200-1N-4T  is given replacement.4461 is not eol announced yet
Good luck
KB
