How to advertise loopback addresses?
huangedmc
Level 3
Level 3
We have 2 3750's connected through routed interfaces on a fiber run.
I was going to run a test to make sure routing works.
After issuing the following into the 3750s, they can't establish neibor status:
ip routing
router eigrp 100
network 1.1.1.1 255.255.255.255
[network 2.2.2.2 255.255.255.255 on the other]
What am I missing? When I turn on debug eigrp, I keep getting messages saying that the 3750 is ignoring HELLO's from itself. How do I advertise the loopback interfaces?
thanks.
mheusinger
Level 10
Level 10
for EIGRP being able to form a neighbor relation, you need at least one common subnet being included in EIGRP. The network statement does two things: tell the EIGRP process which interfaces/networks to include in routing updates and also, where to send hellos and "look" for neighbors. The second part seems to be missing in your config.
If the routed interface bewteen the switches have IP addresses from 10.1.1.0/24 this should look like this:
Switch1:
router eigrp 100
network 10.1.1.0 255.255.255.0
no auto-summary
Switch2:
router eigrp 100
no auto-summary
This should be adjusted to your IP addresses on the routed interface(s).
Hope this helps! Please rate all posts.
Regards, Martin
Edison Ortiz
try
router eigrp 100
network 1.1.1.0
no auto-summary
in the other router
router eigrp 100
network 2.2.2.0
no auto-summary.
Please rate helpful posts.
Do you have a network statment under EIGRP for the routed interface. EIGRP has to establish adjacency for the routes to be exchanged. Do a show ip eigrp nei and see if the neighbor is up.
HTH,
Sundar
mheusinger
Level 10
Level 10
Switch1:
router eigrp 100
no auto-summary
Switch2:
router eigrp 100
no auto-summary
Regards, Martin
Thanks everyone!
Adding the network that the physical interfaces are in did it...
