How to allow ICMP on my router
ekpesinyang
Hello people,
Please I need an assistance. I have a configuration i'm running for a purpose
"ip nat inside source list 101 interface FastEthernet0/1 overload
ip nat inside source static tcp 192.168.0.1 23 195.110.22.30 23 extendable
ip nat inside source static 192.168.1.200 195.110.22.30 extendable"
I'm hosting an application on 192.168.1.200 and my other branch access in from the public IP address : 195.110.22.30. But my problem now is that if i'm pinging from outside the icmp echo is replying from 192.168.1.200 system. I was to redirect the icmp echo to respond on the router rather than going to the system inside because at times if the system is powered off, i cant monitor my up time by pinging. Please Help.
Thank You.
7 Replies 7
Pawan Raut
Level 4
Level 4
You can achieve this using conditional NAT statement for any TCP/UDP traffic redirect to that host and for icmp it should go to any router interafce. Please let me know if you need assistance for router configuration for it.
Pawan
(Make Sure you rate for helpful post)
Pawan, Thank you for your reply. Please Kindly assist me with the config. Thanks.
Hello
@ekpesinyang wrote:
Hello people,
Thank You.
Not sure I understand but first of all why are you using the extendable keyword it only used when you natting with the same inside source address to different port/global addressing etc.
Can you post your full config of nat and access-list 101 please.
Just to confirm you are pinging 195.110.22.30 and it returning 192.168.1.200 correct?
res
Paul
Kind Regards
Paul
Hello paul,
please see the config you requested here.
ip nat inside source static tcp 192.168.1.1 23 197.210.22.30 23 extendable
ip nat inside source static 192.168.1.200 197.210.22.30 extendable
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
@paul driver wrote:
Hello
res
Paul
Can you please clarify the above???
Kind Regards
Paul
Hello Paul Like i stated already, the configuration is to allow me have access to an application hosted on 192.168.1.200 has to be accessed. since i'm not very sure of the port the application is using, i had to give extendable to make sure everything is allowed. Thank you.
can you draw a topoly whats you doing and how your NAT is applying because i am still unable to understand why you using extendable
Zain Khan
https://www.linkedin.com/in/forzain/
