How to Allow pinging of PC-A to Router 1?
JT4
Question
There are two PC's on different subnet masks and the Multilayer switch is how I am doing the routing for them to ping. However whenever I try and ping the router, it always comes back with 'host destination unreachable'. For this particular test i am trying to implement an ACL and know that it is possible on the MLS but then the routing seems to be disabled. Any advice for either reaching the router or implementing the ACL on the MLS?
Answer
Hello
I cannot access the devices in your PT file what are the access credentials?
Kind Regards
Paul
