Help configuring NAT on a Cisco 891F router
gary.cannell1
I'm looking for some help in configuring NAT on my Cisco 891F router.
I have a pool of five public ip addresses provided by my ISP and would like to two of them to provide external access to my security camera's. My ISP also provided an additional router address as part of the public ip address range.
I have assigned the router address to the Dialer1 interface in my router configuration and attempted to NAT using two of the provided addresses as follows
ip nat inside source static udp 192.168.1.2 8000 81.150.26.63 8000 extendable
ip nat inside source static udp 192.168.1.3 8000 81.150.26.64 8000 extendable
The problem I have is I simply cannot get access to my inside network addresses from the outside, I wondered if one of you experts out there would kindly take a look at my configuration to see if there’s anything obvious that I'm doing wrong; one other thing that I did do was to enable autosec_firewall on the router and wondered if this might be having any interference.
Any help is fully appreciated.
Configuration.....
Building configuration...
Current configuration : 4500 bytes
version 15.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
security authentication failure rate 10 log
security passwords min-length 6
logging console critical
enable secret 5 $1$QE2E$cu2ed.d7dKTs6.0ZhJ328/
enable password 7 142417081E573E6A
aaa new-model
aaa authentication login local_auth local
aaa session-id common
no ip source-route
no ip gratuitous-arps
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool vlan1pool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.254
dns-server 213.120.234.70
no ip bootp server
no ip domain lookup
ip inspect audit-trail
ip inspect udp idle-time 1800
ip inspect dns-timeout 7
ip inspect tcp idle-time 14400
ip inspect name autosec_inspect ftp timeout 3600
ip inspect name autosec_inspect http timeout 3600
ip inspect name autosec_inspect rcmd timeout 3600
ip inspect name autosec_inspect realaudio timeout 3600
ip inspect name autosec_inspect smtp timeout 3600
ip inspect name autosec_inspect tftp timeout 30
ip inspect name autosec_inspect udp timeout 15
ip inspect name autosec_inspect tcp timeout 3600
ip cef
login block-for 5 attempts 3 within 5
no ipv6 cef
license udi pid C891F-K9 sn FCZ2214137E
archive
log config
logging enable
username Grid password 7 097F4B0A0B560353
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
duplex auto
speed auto
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
description ### WAN interface ###
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
ip address 192.168.1.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface Async3
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation slip
interface Dialer1
ip address 81.150.26.30 255.255.255.248
ip access-group autosec_firewall_acl in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
ip inspect autosec_inspect out
ip verify unicast source reachable-via rx allow-default 100
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname C000332@hg28.btclick.com
ppp chap password 7 1414130502512628757A60
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended autosec_firewall_acl
permit udp any any eq bootpc
deny ip any any
logging trap debugging
logging facility local2
no cdp run
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 100 permit udp any any eq bootpc
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
banner motd ^CUNA^C
line con 0
exec-timeout 5 0
login authentication local_auth
no modem enable
transport output telnet
line aux 0
exec-timeout 15 0
line 3
exec-timeout 15 0
modem InOut
speed 115200
flowcontrol hardware
line vty 0 4
transport input telnet
scheduler allocate 20000 1000
end
Router#
Configuration.....
version 15.3
no service pad
hostname Router
boot-start-marker
boot-end-marker
aqm-register-fnf
aaa new-model
no ip source-route
no ip bootp server
no ip domain lookup
ip cef
no ipv6 cef
archive
log config
logging enable
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation hdlc
shutdown
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
duplex auto
speed auto
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface Async3
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation slip
interface Dialer1
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
no ip http server
deny ip any any
no cdp run
control-plane
banner motd ^CUNA^C
line con 0
exec-timeout 5 0
no modem enable
line aux 0
exec-timeout 15 0
line 3
exec-timeout 15 0
modem InOut
speed 115200
line vty 0 4
end
Router#
3 Accepted Solutions
Hello
Your static nat configuration is okay however you have CBAC applied with unicast reverse path forwarding in strict mode.
If you amend the CBAC & uRPF access control lists to allow communication to these hosts then it should work, please apply the below changes and test again.
permit udp any any eq 8000
deny ip any any
ip access-list extended 100
Kind Regards
Paul
thanks for clarifying. I suppose Paul's post provides the solution, but since I have been looking at your config as well, I have come up with a solution that moves the entire inspection to the inside. The config would look as below The logging and ICMP stuff in the access lists is for verification, you might want to remove these once the connectivity works).
One small thing, also exclude the IP address of the VLAN 1 interface from the DHCP pool.
ip dhcp excluded-address 192.168.1.254
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip inspect autosec_inspect in
interface Dialer1
ip access-group autosec_firewall_sec in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
permit tcp 192.168.1.0 0.0.0.255 any
permit udp 192.168.1.0 0.0.0.255 any
permit icmp 192.168.1.0 0.0.0.255 any
deny ip any any log
ip access-list extended acl_firewall_sec
permit icmp any 81.150.26.24 0.0.0.7 unreachable
permit icmp any 81.150.26.24 0.0.0.7 echo-reply
permit icmp any 81.150.26.24 0.0.0.7 packet-too-big
permit icmp any 81.150.26.24 0.0.0.7 time-exceeded
permit icmp any 81.150.26.24 0.0.0.7 traceroute
permit icmp any 81.150.26.24 0.0.0.7 administratively-prohibited
permit udp any 81.150.26.24 0.0.0.7 eq 8000
deny ip any any log
Hello
@Georg Pauwen  i see you have amended the cbac acl for icmp, - FYI though cbac has a icmp feature to call on just for this reason  if you wanted to allow icmp
ip inspect name autosec_inspect icmp
Kind Regards
Paul
6 Replies 6
the three IP addresses (the Dialer interface IP address and the two static IP addresses) all belong to different subnets:
81.150.26.63/29 --> broadcast address of subnet 81.150.26.56/29
81.150.26.64/29 --> subnet address of subnet 81.150.26.64/29
81.150.26.30/29 --> belongs to subnet 81.150.26.24/29
If your provider gives you 5 public IP addresses, they should be contiguous. Since you have a /29 subnet mask, check if the below addresses are usable:
81.150.26.25/29
81.150.26.26/29
81.150.26.27/29
81.150.26.28/29
81.150.26.29/29
Hi Georg,
My apologies for causing some confusion here. For security reasons I attempted to mask the real addresses being used not realising that I had invalidated the range.
The ip address range provided by my ISP are contiguous, they are:
81.150.26.25 to 81.150.26.29 and a router address of 81.150.26.30
IPv4 Network address 81.150.26.24
IPv4 Router address: 81.150.26.30
IPv4 Subnet mask: 255.255.255.248
Thank your for taking a look at this, Is there anything within the rest of my configuration that might be causing the issue
Gary
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface Dialer1
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
deny ip any any log
deny ip any any log
Hello
Kind Regards
Paul
Hello
deny ip any any
Kind Regards
Paul
I’ve implemented the changes as suggested and all appears to be working now.
Thank you for your time looking into this.
Best Regards
GaryC
