How to assign LAN IP to WAN Port rv345 Dual WAN Router
The T-Man
Hi guys,
As the subject line states, can this be accomplished via the rv345 GUI?
To be clear, I want to assign a client machine on my LAN to use a specific WAN port (1 or 2).
Your thoughts
balaji.bandi
As per my understanding, you want to send LAN device XY to WAN1, and ZZ to WAN 2 port s this correct- then PBR is the question to send using WAN 1 or WAN 2 port.
if the above statement is correct, then your subject is wrong. "How to assign LAN IP to WAN Port rv345 Dual-WAN Router"
BB
The T-Man
Hey BB,
Thanks for this. Wasn't sure what the right subject line would be.
Can you point me to some documentation regarding PBR specific to this router?
balaji.bandi
check do you have option available under
Networking ---Routing--Policybased routing ?
BB
