how to assign multiple ip addresses to a cisco router interface
n.bokhar1
hi i have 10 private ip address i want to assign them to one interface on my router and then use nat to pat some of them and also static nat and port forward the rest how can i achieve that i have a 4331 router
2 Accepted Solutions
Kevin SAS
If I understand well, you should configure something like that :
int Gi 0/0
desc IN
ip address 192.168.2.1 255.255.255.0 secondary
ip address 192.168.3.1 255.255.255.0 secondary
ip nat inside
int dialer 0
desc OUT
ip nat out
And then configure your pat as usual :
ip nat inside source static tcp 192.168.2.10 80 int dialer 0 80
Then access to the required through
Dialer_IP:80
Verify your ppat with "show ip nat transl"
Hope it helps
you can assign multiple IP addresses to the same interface, and then use NAT/PAT the same way as if you would use the primary IP address.
Is this what you are asking ?
Below is what I mean:
interface FastEthernet0/0
description WAN interface
ip nat pool NAT1 192.168.2.1 192.168.2.1 netmask 255.255.255.0
ip nat inside source list 1 pool NAT1 overload
ip nat inside source static tcp 10.10.10.1 80 192.168.3.1 80 extendable
7 Replies 7
Kevin SAS
int Gi 0/0
desc IN
ip nat inside
int dialer 0
desc OUT
ip nat out
Dialer_IP:80
Hope it helps
Hello
I know this is an old thread but I have the same router and cannot get this to work. There is a bug for this but can you tell me what IOS XE you are running?
Thank you
Joseph
n.bokhar1
thanks guys it worked perfectly
Sorry for wrong placement of reply
Hello
Thank you
Joseph
@n.bokhar1 which solution works perfectly? Kevin's or George's?
both 'solutions' essentially say the same thing. You can either use static NAT and secondary addresses, or put the secondary address in a pool and use that pool for dynamic NAT.
