How to block Traffic from a specific network in a router
keeran
I have the following subnets below.  i want to let traffics from the green subnet to go everywhere but the blue subnet(DMZ) should not be able to get into the green Network. How do i prevent the blue network get into the green network ? what should i do on my router ? cisco_03.JPG
3 Accepted Solutions
Martin L
simply do extended ACLs on router; technically, real world solution would be a Firewall but for CCNA exam cert, ACL is ok.
Regards, ML
**Please Rate All Helpful Responses **
Hello
You can negate access (tcp) with a routed-access list, as for udp that is  connectionless so you would have to either allow/deny specific udp traffic both ways.
example:
ip access-list extended blue-access
permit tcp 192.168.127.0 0.0.0.255 any established
deny tcp 192.168.127.0 0.0.0.255 any
permit ip any any
int vlan x (green l3 interface)
ip access-group blue-access out
Kind Regards
Paul
Old way was Copy into notepad and edit there then copy and paste acl back into router.  Using no access-list x will delete all lines/entries in ACL x on router.  new option -called Named mode- came out in order to edit acl on device itself.
First of all, Only if you see sequence numbers in front of acl statements when you do show ip access-list.  IOS adds sequence numbers to ACL since version 12.2 I think or 12.4.  Then you can use Named ACL which start with ip access-list  not  access-list.
in any case, you must get into Named mode to see no option or sequence numbers to edit acl (see example below).
Example:
Router(config)#ip access-list extended 100
Router(config-ext-nacl)#?
<1-2147483647> Sequence Number
default  Set a command to its defaults
deny  Specify packets to reject
exit  Exit from access-list configuration mode
no  Negate a command or set its defaults
permit  Specify packets to forward
remark  Access list entry comment
Regards, ML
5 Replies 5
Martin L
Regards, ML
Hello
example:
permit ip any any
Kind Regards
Paul
how can i change the access list order ? like how can i move the permit any any rule to the bottom ?
Example:
Regards, ML
thank you. That helps :))
could you take a look at my other question ? I think you will be able to answer that too. You find it in my profile
