to a dns-server through two Routers with different subnet
keeran
Hallo.
I have the following network. I have already set the red router, sothat i can reach the google-server from all of my network(DMZ, LAN & Public). Now i am trying to simulate a backup ISP(the green router). The aim is to be able to ping bthe google server even if the ISP 1(the red) is down. I need to have the google server fa0/0 of red network and fa0/0 of green network in the same subnet. How do i configure static route on my intern router(the third router at the bottom) ?
Giuseppe Larosa
Hello @keeran ,
first of all you need a larger target subnet as 8.8.8.8/30 allows for only two hosts.
At least you need
8.8.8.8/29
on the bottom router you will have
ip route 8.8.8.8 255.255.255.248 10.0.10.11
and a floating static route ( with an higher Admin distance ) via the backup router/ISP
ip route 8.8.8.8 255.255.255.248 10.0.20.11  220
in real world you could use either an IP SLA or a routing protocol like eBGP to check the primary path.
Hope to help
Giuseppe
Giuseppe Larosa
Hello @keeran ,
At least you need
8.8.8.8/29
Hope to help
Giuseppe
just to make sure I understand correctly, so in your command "ip route 8.8.8.8 255.255.255.248 10.0.20.11  220" the 220 means: my router will normally send the google Traffic to the Router ISP1(10.0.10.9). Onyl if the ISP 1 Router isn't available for some reason, my router will decide to send the google traffic to the ISP 2(10.0.20.9). Is it right ?
Hello
conditional ip sla static default routing  -
The example below will allow default routing to take isp1 path and if that fails in relation to ip sla monitoring  then the isp2 path will take precedence
your rtr
ip sla 1
icmp-echo 8.8.8.9 source- interface fa4/0
ip sla scheduled 1 start-time now life forever
track 10 rtr 1 reachability
ip route 0.0.0.0 0.0.0.0 fa4/0 10.0.10.9 track 10
ip route 0.0.0.0 0.0.0.0 fa6/0 10.0.20.9 200
Kind Regards
Paul
