- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-06-2014 10:13 PM - edited 03-04-2019 11:29 PM
i am not able use thse firewall policy in my cisco 3750
Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
System image file is "flash:/c3750-ipservicesk9-mz.122-55.SE8.bin"
it only show's- match protocol http
host or url are not in there
can i have to upgarde IOS or these camands are not ther in 3750 switch.
how can i use that pls tell me m w8ing for ur response
Solved! Go to Solution.
- Labels:
LAN Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-07-2014 01:09 AM
You need to upgrade your IOS to 12.2 (55)SE.
Following can might help you with:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swacl.html
Cheers :)
Waqas
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-07-2014 01:09 AM
Cheers :)
Waqas
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-08-2014 03:26 AM
hi waqas,
the link you have send does not show's that 3750 switch with IOS 12.2.(55)SE has the cammand
match protocol http url
or
match protocol http host
I have search it on many books i didnt find it.
as this switch is our core switch so i dont want take any risk until it is sure that on IOS 12.2(55) SE these camands are available.
regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-10-2014 12:12 AM
Hi Srivastava,
Apologize for the late response, please have a look a the following statement from cisco on "match protocol http or url" here...
http://www.cisco.com/c/en/us/td/docs/ios/qos/command/reference/qos_book/qos_m1.html#wp1058795
match protocol http
To configure Network-Based Application Recognition (NBAR) to match HTTP traffic by URL, host, Multipurpose Internet Mail Extension (MIME) type, or fields in HTTP packet headers, use the match protocol http command in class-map configuration mode. To disable NBAR from matching HTTP traffic by URL, host, or MIME type, or fields in HTTP packet headers, use the no form of this command.
Cisco IOS Release 12.4(24)T and Earlier Releases, Cisco IOS Release 12.2(33)SRA, Cisco IOS Release 12.2(14)S and Later Releases
match protocol http [url url-string | host hostname-string | mime MIME-type | c-header-field c-header-field-string | s-header-field s-header-field-string]
no match protocol http [url url-string | host hostname-string | mime MIME-type | c-header-field c-header-field-string | s-header-field s-header-field-string]
Cisco IOS Release 15.1(2)T, Cisco IOS XE Release 3.1S and Later Releases and Catalyst 6500 Series Switch Equipped with the Supervisor 32/PISA Engine
match protocol http [content-encoding content-encoding-name-string | from from-address-string | host hostname-string | location location-name-string | mime MIME-type | referer referer-address-string | server server-software-name-string | url url-string | user-agent user-agent-software-name-string]
no match protocol http [content-encoding content-encoding-name-string | from from-address-string | host hostname-string | location location-name-string | mime
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-07-2014 06:08 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You might find 3750 NBAR like features rather lacking.
If so, you can also write ACLs that match against IP addresses and/or port numbers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-08-2014 03:10 AM
hi josheph,
i have tried to block facebook and youtube by thease access list. but it blocks all the sites. as thease are only youtube and facebook ip's
access-list 101 deny tcp any host 173.252.110.27 eq www
access-list 101 deny tcp any host 31.13.68.8 eq www
access-list 101 deny tcp any host 173.194.36.72 eq www
access-list 101 deny tcp any host 173.194.36.73 eq www
access-list 101 deny tcp any host 173.194.36.78 eq www
access-list 101 deny tcp any host 173.194.36.64 eq www
access-list 101 deny tcp any host 173.194.36.65 eq www
access-list 101 deny tcp any host 173.194.36.66 eq www
access-list 101 deny tcp any host 173.194.36.67 eq www
access-list 101 deny tcp any host 173.194.36.68 eq www
access-list 101 deny tcp any host 173.194.36.69 eq www
access-list 101 deny tcp any host 173.194.36.70 eq www
access-list 101 deny tcp any host 173.194.36.71 eq www
access-list 101 permit tcp any any eq www
interface gi0/1
ip access-group 101 out
kindly suggest whats wrong in this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-09-2014 03:42 AM
Disclaimer
Posting
Your int g0/1 is egress facing Internet?
Did you really want to block all other outbound traffic but port 80? If not, try a permit ip any any at the end of your list rather than the permit tcp any any eq www.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-09-2014 10:56 PM
users can access youtube and fb using proxy.
and youtube and fb will have more IP addresses later
best way is nbar. but 3750 looks like not support nbar
using nbar
match protocol http host youtube
match protocol http host facebook
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-07-2014 07:08 AM
If you are planing to do more of filtering (blocking urls, apps etc) I'd suggest to purchase a Firewall, cisco or other vendor (better than cisco for FW), because router/switch simply cannot do it :)
-Brj
