how to capture packets on Cisco 7206VXR NPE-G2?
gimsherpa74
Hi there,
I am attempting to capture packets on Cisco 7206 as I am able to do so on other models with the following or similar commands:
monitor capture ....................
but I can't find "capture" option on 7206. When I do issue monitor command, these are the only options I see:
call
event-trace
processes
traffic
Can someone please assist me on this so I can capture packets? Thank you.
Seb Rupik
Hi there,
What version of IOS are you using? EPC (Embedded Packet Capture) is supported on the NPE-G2 on versions 15.0(1)M4 and above.
Another solution may be to place a catalyst switch inline with the interface you are trying to capture on and configure a SPAN port.
cheers,
Seb.
Hi Seb,
Unfortunately, I am on 12.4(4)XD5.
Ah, well in that case if you cannot get hold of a newer version of IOS which supports EPC your only other option is to place a switch inline and run a SPAN port.
cheers,
Seb.
